Old Jun 11, 2019 | 09:36 AM
  #6731
Jeff Blake's Avatar
Originally Posted by whowa004
I was going to but I had rushed an already ordered the TF shocks. UPS and USPS wanted an outrageous amount to return the TF so I could get the Fox. I goofed and will live with it and when they wear out just means hopefully I'll be done renovating my house and I can go a little more custom and try to max out travel without going any higher..
I have been hesitating on cutting the rears. Do you know if anyone has done a how to on the process or maybe a pic or two? It seems fairly straight forward but body work is not really a strong suit of mine.
It's pretty straightforward, there are some pics on the old Discoweb site, and a youtube video from "Tinker", search discovery 2 flexi flare install
I just did it. Did a rough cut with the angle grinder cut off wheel, then cleaned it up with a flap disc.
Trim and seals I used:
https://www.amazon.com/gp/product/B00NDR28JI/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00NDR28JI/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00NL450WA/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00NL450WA/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Used this to cover up the fender edges. It looks pretty good, but it would look better if you get a more bulbous/thicker trim
https://www.amazon.com/gp/product/B00KGAKG2G/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00KGAKG2G/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
I also cut the fronts, and since the inner fender no longer fit well, I got a sheet of Kydex plastic and formed new ones.
Old Jun 11, 2019 | 10:17 AM
  #6732
whowa004's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks, I had been meaning to watch the "Tinker" video. Did you opt to no use the big flexi flares and just run an edge trim over cut areas? How does the rear look if not using the flexi flares?
Old Jun 11, 2019 | 10:25 AM
  #6733
Jeff Blake's Avatar
I'll get some photos later. I didn't do flares, not really keen on paying $300+ for flimsy plastic... it would probably look better, especially because I took off Terrafirma flares which were screw in, so I'm trying to cover up those holes.
For the fronts I'm having a welder make brush guards (steel tubing) to connect from the rock sliders to bumper
Old Jun 11, 2019 | 10:51 AM
  #6734
whowa004's Avatar
makes sense. A few pics would be great! I'm also not a fan of the way the flares look on a white disco especially with the price tag. I can clean up my cuts to make them all a little more uniform (still need to do that in the front) After watching the video I'm a little concerned with how it would look without the flares especially with the door molding added back on and the amount of silicon used.
Old Jun 11, 2019 | 08:11 PM
  #6735
Jeff Blake's Avatar
I didn't use any silicone, nor the original rubber seals. I replaced them with those amazon links and they fit perfectly, no silicone necessary
Today I deleted the washer reservoir due to tire rubbing and put in a smaller tank. Saved about 22 pounds (terrafirma bumper washer bottle guard + reduced capacity)
In progress I am working on fitting rear hydraulic bump stops and new springs
Old Jun 11, 2019 | 10:17 PM
  #6736
whowa004's Avatar
Let me know how the bumpstop project turns out. Definitely something I'm looking into down the road.
Old Jun 13, 2019 | 09:46 AM
  #6737
shaneb24's Avatar
Default I found this at the bottom of my oil Pan
. I think the best course of action is just to pretend we never saw anything.
Old Jun 13, 2019 | 09:51 AM
  #6738
mollusc's Avatar
is that a piston skirt?
how would that even happen??
Old Jun 13, 2019 | 10:02 AM
  #6739
SuperSport's Avatar
Good idea. That appears to be an extra part you don’t need. They throw them in the oil pan just in case.
Old Jun 13, 2019 | 10:37 AM
  #6740
JoJo The Giraffe's Avatar
Land Rover's version of the fortune cookie. You never know what's inside. Putting the fun aside, your vehicle still works?
