#8372
Rebuilt ujoints & rear driveshaft upgrade conversion
Finally got this last major work done by the shop. Ordered the rear driveshaft conversion to get rid of the rubber damper. Vibration on acceleration gone! And all ujoints have serviceable zerks ☺️
Rear drive shaft upgrade conversion removing damper design
Front half of rear shaft going to transfer case (serviceable ujoints!)
Rebuilt from shafts with 1310 ujoints ☺️
Daytoman (08-19-2021)
#8373
Typically, if there is no reading from O2...it will default to +25% fueling. If you threw a reader on it, you'd probably see +25% reading on short and long trim trims. Usually short term trims will be bounce between -10% and +10% at steady speeds or idle...on a clean running engine with no other codes.
When l had a bad 02 on my old 03, stripped threads and took a couple days to get a tap, had it plugged off, right bank +25% constant...anyhow...it got about 11.5 mpg...painful...lol.
Checked the mileage on the 04 the last two tanks...getting around 15.5 mpg. Actually pretty happy with that.
You can see from the photos the 02s are dead, fuel trims are locked at zero.
The Deputy (08-14-2021)
#8374
Interesting, it's like the ECM is not receiving or sending data required...but it runs fine. You may have just discovered the best way to make a Dll run...but we don't know how it's doing it...lol. Weird.
Another weird thing...you've already been running errands this morning...and l'm still working on my first pot of coffee. I think l've got to get in touch with a motivational speaker or something...lol.
#8375
The following 2 users liked this post by Extinct:
The Deputy (08-14-2021),
The_OGCJR (08-19-2021)
#8376
#8377
I actually did stumble upon the best way to run a D2 here a few months back. I was chatting with a guy in South Africa who was buying one of the in line kits and he informed me that the South African petrol trucks never came with oxygen sensors because they only had leaded fuel and so the ECU program for those trucks is mass air flow only. I know my guy at EuRover in Greenville South Carolina was able to flash my ECu with whatever year model I wanted because I've changed a 2003 ecu to running one of my 00 without SAI. I assume he could Flash in a South African ECU program and viola no more oxygen sensors
interesting
oxy sensors have caused more grief here over the years
Richard Gallant (08-14-2021)
#8379
Went out and had a bit of fun yesterday on a whim. I was alone, trail was empty, didn't even have my winch. I played it safe most of the day, but I did hit one hole I had been through quite a few times before.
Well I didn't take into account that my CDL is out right now and almost got myself into a pickle. Captured on video. Here are a few shots from the day!
Small river crossing. Water was way down. Sometimes when it has been raining, water will splash over your hood.
Wheel shot.
Dog getting muddy.
Washing the dog before she gets back in the truck.
Almost stuck. Definitely had an "oh crap" moment.
Wheel shot.
Dog getting muddy.
The following 7 users liked this post by Alex_M:
acg (08-17-2021),
ckadventure (08-16-2021),
T-rex (08-16-2021),
The Deputy (08-15-2021),
The_OGCJR (08-19-2021),
and 2 others liked this post.
#8380
Nothing but drive the heck out of both of them. Seriously contemplating dropping the green disco down to stock height and tire size as it's turned into much more of a daily. Plus the classic could use the suspension that's in it. It desperately needs a quick refresh and I don't feel like buying new stuff.
