Old 11-22-2021 | 01:10 PM
Richard Gallant's Avatar
@North the thermostat part is easy open the hood. If you have an aluminum housing sitting on or near the fan shroud in-line if you have hose or hoses with a plastic T stock.
  #8552
Old 11-22-2021 | 01:22 PM
North's Avatar
Ah, I see thank you. I have the plastic one. I'll have to replace that for sure.
  #8553
Old 11-22-2021 | 07:36 PM
Extinct's Avatar
Originally Posted by North
Just a question, and I know how to search the forums, but this is one of those things that has more than one answer or no definitive answer (perhaps).
The inline thermostat mod, my thermostat was replaced before I purchases the vehicle. How do I determine if it's the inline one or (the standard) one?
Thanks. And I will look into the PCV mod., Anything I can do to get the most amount of time out of this.
Read all the Stickies.
Take a look at these also:https://landroverforums.com/forum/discovery-ii-18/2001-discovery-2-60-000-miles-what%92s-fair-price-92717/page3/#post674154
https://landroverforums.com/forum/discovery-ii-18/there-seat-trim-inboard-side-front-seats-96444/#post723598
  #8554
Old 11-23-2021 | 06:53 AM
redrover75's Avatar
I finally have no lights on the dash. unbelievable. knock on wood.
Was getting a P1415 I could not chase to save my life. Did the Hyundai valve, the chased lines and SAI valves, replaced the SAI pump. Which is much quieter now. The trick was the little valve next to the Hyundai valve. The rover one was ~$50, strangely, the BMW one was $20. BMW, Land Rover Vacuum Control Valve - PIERBURG - 7.02318.01.0 - NEW OEM
Credit to Rover Master, the guy who pinned my cylinders and did some other work. If you need anything done outside of your DIY scope, totally worth getting the truck to him. Super knowledgeable.
Replaced the ABS pump, got rid of my four Amigos. That is nice. Knock on wood again.
I have a set of 2" lift spaces that I am going to install next time we have warm day, looks like a pretty simple install.
The following 2 users liked this post by redrover75:
ckadventure (11-24-2021), cvhyatt (11-24-2021)
  #8555
Old 11-24-2021 | 04:24 PM
cvhyatt's Avatar
@mln01 - My temps are usually in the low 190's but when I get on the highway at those speeds, I'm usually up around 215-217. What have you done to your rig to run it at such low temps? Do you still have the stock air scoop under the front bumper?
  #8556
Old 11-24-2021 | 04:43 PM
Mullins.cody's Avatar
bought a genuine 180 thermostat from lucky 8. Replaced fan clutch and radiator. Cruising temp is 188.6 and at idle usually 194-203 havnt seen over 205 yet.
  #8557
Old 11-24-2021 | 04:45 PM
andino's Avatar
I've got an inline thermostat and rarely see above 200 even on the highway at 75-80 unless it's really warm out.
  #8558
Old 11-24-2021 | 05:05 PM
Daedrix's Avatar
Banned
My 03 ls swap sat in my backyard for about a year due to me away for work. When i got back rats have somehow got inside and destroyed everything from seats to multiple harnesses. So i bought an 04 to replace it and currently on the process taking the good parts ot in order to swap em over.
  #8559
Old 11-24-2021 | 05:12 PM
cvhyatt's Avatar
I did that too but I used a cheap amazon radiator core. Does the mfg of the radiator make a difference?
  #8560
Old 11-24-2021 | 05:27 PM
hmmm i have a nissen radiator. Seems to be working very well. Would also think about water pump idlf havnt changed yet
Quick Reply: What did you do with your DII today?
