Stuck in Park, F on dash and TCM + ACTM errors?
Old Dec 20, 2025 | 02:46 PM
archaeology_student's Avatar
Default Stuck in Park, F on dash and TCM + ACTM errors?
Replaced a zombie battery in my 2006 LR3 HSE and a majority of my error codes went away.
However, my 4x4 info display screen, and radio remain on when I leave the vehicle and the screen says the key is still in the ignition when it isn’t. I do realize my fob battery is dead…
There was some water ingress and the drainage tubes have been cleared. Also replaced the brake light switch just to be safe.
To re-iterate:
- fresh new battery
- new park brake switch
- radio, 4x4 info screen and message key in ignition when I remove the key
The shifter has been stuck in park with an ‘F’ on the dash for a fault. I have been able to shift using the emergency button under the shifter but what else should I be drying out or checking?
Regarding codes, these are the codes that pop up:
All Terrain Control Module (ACTM):
U0402-94
U0416-94
U0421-94
Transmission control module (TCM):
P0659-00
Thanks for the help!
Old Dec 21, 2025 | 11:22 AM
CantComplain's Avatar
Any chance you got water into the shifter console? See https://landroverforums.com/forum/lr...ailable-23880/ Regardless, with codes for the shifter and terrain control, and them being located in the same space, I'd dive in there and see if you can clean up in that general area.
Old Dec 21, 2025 | 05:38 PM
Gnomadf's Avatar
It would be worth pulling the console and cleaning the circuit boards. I found a lot of corrosion and what appreared to be dried soda or coffee distributed through the boards.
TripleF_67
Apr 19, 2025 02:45 PM
Jennifer Fox
Nov 21, 2020 02:06 AM
HammerFit
Sep 10, 2014 05:27 PM
pedro_malo
Aug 25, 2014 06:58 PM
josemex
Dec 20, 2009 08:38 PM
