In Control Pro with Verizon
Old Oct 10, 2018 | 09:04 PM
BritCars's Avatar
Default In Control Pro with Verizon
My 3 month ATT free data is about to expire. Would like to just add the Discovery onto my Verizon plan as an additional data device (like an iPad etc). Any idea if that's possible? Seems very unclear what networks can be the provider
Thanks.
Old Oct 10, 2018 | 09:20 PM
I would guess that depends if it has CDMA capability since ATT is GSM. If there is a spot for a sim card you could just try putting your verizon sim in it to see if it works
Old Oct 10, 2018 | 11:10 PM
abran's Avatar
We were told not to swap in a new SIM. The dealer said add the SIM onto our plan.
going to do it this month, I’ll report back
Old Nov 22, 2018 | 09:15 AM
BchBum11511's Avatar
My free ATT trial is ending soon. I have Verizon for my phones, and I've been dissatisfied with my ATT coverage. Were you able to get it added to your Verizon plan? Any noticeable better coverage?
Old Dec 5, 2018 | 10:04 PM
DeckB's Avatar
My guess is the dealer suggested using the 'OEM' SIM to be sure it's a data only card.
Most carriers have data-only devices and plans, so I assume you can find a data-only card if need be.
Old Dec 6, 2018 | 09:29 AM
abran's Avatar
We added the existing sim to our plan at ATT.
Old Dec 6, 2018 | 04:13 PM
andries's Avatar
Verizon is CDMA, so I doubt the D5 will work on it. AT&T is GSM and I think in the US the only other option will be T-Mobile (but I think AT&T coverage is better). Since the D5 was build in Europe I think it may only support GSM based networks. I may be wrong, but have not seen anybody use Verizon with it.
Old Dec 6, 2018 | 08:53 PM
jaguardoc504's Avatar
As already stated, the D5 uses a GSm network, so adding to Verizon will not be an option.
I already tried, and was told by both Verizon and the Dealer is cannot be done.
Old Dec 6, 2018 | 09:26 PM
DeckB's Avatar
See my other post(s) regarding using a phone as a 'hotspot'. It's a good workaround to get a CDMA connection in the car.
Old Dec 8, 2018 | 06:52 PM
BritCars's Avatar
I heard that freedompop has a free data only sim plan that works with InControl. Not sure if true - I ordered one and will test it when mine stops working
Drake Anderson
May 13, 2019 08:31 PM
Ianegrace1
Range Rover Evoque
Apr 6, 2019 10:14 AM
preeble
Dec 6, 2018 09:32 PM
natelw
Nov 20, 2018 02:00 PM
ToiletDuck
Nov 18, 2018 03:45 PM
