My D5 build 2017 TD6 HSE Lux
Old Jan 4, 2023 | 11:21 AM
  #211
gmfain's Avatar
Originally Posted by BritCars
Mine is the V6 gas supercharged. That one is the newer version of mine (I have the V2). Functionally the same and it should absolutely do it. See user manual. So if it's not working it suggests maybe something wrong with the software on your car. Perhaps explains why the manual reset isn't working on yours either...
It would not do it. I was in contact with the manufacturer. When the manufacturer says it won't, that was good enough for me.
Take time to go back through everything I have posted about this specific issue. ( in short, only 2017 diesels has this issue)
The V6 gas supercharged, can be reset without a scanner.
Old Jan 4, 2023 | 06:27 PM
  #212
BritCars's Avatar
It's weird that it does it for the gas but not the diesel. Same problem as for the manual reset too. I guess if you've found a scanner that actually works on your one, then problem solved. But sounds like it gave you quite a run around...
Old Jan 12, 2023 | 05:30 PM
  #213
gmfain's Avatar
I received the Launch CRP909.
It has a lot of functions. I was able to oil/service reset.
Oil change coming up this Saturday. (8K)
I'll post some pictures...
Old Jan 13, 2023 | 01:34 PM
  #214
bkjecu94's Avatar
Will the Launch CRP909 do anything else?
I guess a better question is... What else does it do?
Old Jan 14, 2023 | 07:57 PM
  #215
gmfain's Avatar
It has a pretty long list. I haven't tested other features out personally.
Old Jan 14, 2023 | 08:43 PM
  #216
gmfain's Avatar
Here is pics from my PM today. Using the Launch crp909 to reset.
All the goodies.
Don't pressure wash off all the dirt and mud. when it dries, a leak with jump out at ya!
no leaks here.
MAP sensor build up.
Launch crp909
good to go
Old Jan 15, 2023 | 05:18 AM
  #217
pernison's Avatar
Hello, exact model of CRP909? Thank you.
Old Jan 15, 2023 | 05:49 AM
  #218
gmfain's Avatar
Launch crp909
https://www.walmart.com/ip/LAUNCH-CR...hoC3uIQAvD_BwE
Old Jan 15, 2023 | 07:53 AM
  #219
bkjecu94's Avatar
All supplies via Rockauto?
Old Jan 15, 2023 | 09:02 AM
  #220
pernison's Avatar
Thank you, in a single oil change it would already be amortized.
