My D5 build 2017 TD6 HSE Lux
Old Jan 15, 2023 | 07:59 PM
  #221
gmfain's Avatar
Originally Posted by bkjecu94
All supplies via Rockauto?
Rockauto all the way!
Old Apr 7, 2023 | 12:06 PM
  #222
mtaylo32's Avatar
Originally Posted by gmfain
DEF Injector cleaning. 2017 D5 TD6
Located Driver Side, just past 2cd factory skid plate.
Most of build up stuck to the other side.
The build up just dropped off.
I cleaned with a hand held steamer. Water/steam only.
Some notes:
My rig has 60K.
The screw that holds the clamp is rotated to the top.
I re installed rotated down in a easier position to re tighten.
TIP: During reassembly, position injector( it only go one way) squeeze clamp together, push the locking tab down, then reinstall the screw.
Feel free to shoot any questions my way.
Thanks for this write up. Is this a relatively easy job with the handheld steamer? Can you wipe away the build up with a rag or is the injector finicky? Appreciate you!
Old Apr 7, 2023 | 03:27 PM
  #223
1979rover's Avatar
Do you happen to know where the DPF is? Is it fairly accessible?
I’m looking to give it a flush when the weather warms up and will need access to the sensor port.
Thx
Old Apr 8, 2023 | 12:56 PM
  #224
gmfain's Avatar
Thx
I have not even thought about the DPF location. But I will take a look and get back to you on that one.
Old Apr 9, 2023 | 06:25 PM
  #225
1979rover's Avatar
Cheers, that would be amazing.
Old Sep 15, 2023 | 05:00 AM
  #226
gmfain's Avatar
Sorry for the delay.
Here is a good breakdown of the DEF system.
https://www.scuderiacarparts.com/par...7447?h=1061799
Old Apr 18, 2024 | 12:30 PM
  #227
gmfain's Avatar
I'm still here. Changed jobs, and all that mess...
Beast.
Old Apr 18, 2024 | 04:27 PM
  #228
LR disco 5's Avatar
Great to see this thread back whens the detailed transmission fluid change coming out.
Old Apr 18, 2024 | 06:58 PM
  #229
gmfain's Avatar
Next weekend is my target,
Going in the morning to dealer for a recall notice. Supose to fix the Nox issue/ something like that.
Old Apr 18, 2024 | 08:08 PM
  #230
ar077's Avatar
Is there any intel regarding the recall? What exactly is the problem and does the solution result in any impacts to performance, fuel economy, or reliability?
