Is there any intel regarding the recall? What exactly is the problem and does the solution result in any impacts to performance, fuel economy, or reliability?
Sorry I left the recall paper at work. I'll upload a copy.
Just had the recall done for both the NOX/PCM and the rear door latch issue. The NOX/PCM software update has seemed to fix the clunk in the differential/transfer case that many have spoken about here. We don't have any emissions testing in Kentucky so it wasn't a crucial thing to have done, just wanted to latest software. Both recalls took about an hour total at the dealer. The rear door latch they just check for water ingress, if the vehicle shows signs then they replace whatever parts needed, thankfully mine did not have it.
I clean it every oil change.
Also clean DEF injector. ( I ran out of time to clean DEF injector)
Is it just a matter of spraying the MAP with some brake cleaner, or something more involved? https://www.autozone.com/diy/engine/...n-a-map-sensor
Thank you for sharing your maintenance on the D5. It benefits many of us newbies
Your welcome.
I prefer not to use the MAF cleaner.
I just wipe the outside. Then carefully loosen soot with a pick, Don't go to deep, then use a Qtip/cotton swab circles not in and out.
Thanks to @gmfain for sharing his knowledge with us. I was able to clean the DEF injector & MAP sensor. Both turned out to be super easy maintenance items
T25 Torx to remove the bolt Minor build-up at 39K; it all fell out with a touch of hand few finger taps is all it took to drop all the build-up on the ground Initially had a challenge to remove the sensor Then realized there is a tab to push in; voila!
