GAP IID Tool Summary
Old Sep 13, 2024 | 06:25 PM
  #341
cc1999's Avatar
Your V8 has it, too. In fact, in the initial Defender V8 press release was the first time JLR publicly stated that the Defender has fake engine noise in any PR material.
Interesting, I hadn’t really noticed it, I guess it must sound ok.
It’s way too quiet in anything but dynamic mode where I have it programmed to keep the exhaust valves open.
Old Sep 14, 2024 | 06:38 AM
  #342
goofdunk's Avatar
Hi, does anyone know if it is possible to code in lane centering during adaptive cruise control?
Thanks
Old Sep 16, 2024 | 12:53 PM
  #343
LL247's Avatar
I'm just here to say THANK YOU for this thread. Finally got my GAP tool and unlocked the one thing I've missed with the new(ish) Defender, adaptive cruise. It was honestly one of the reasons I never made my last 110 the primary daily driver, living in Texas everything is a 30 min highway drive.
Old Sep 16, 2024 | 03:40 PM
  #344
D110Xd's Avatar
Also, in the Defender V8 video put out by JLR they have a close up of the speaker grill while the driver is in dynamic mode around the 33 second mark.
Old Sep 17, 2024 | 12:51 PM
  #345
cc1999's Avatar
I have been getting JLR alerts in my main screen, that there is an update available for download on my Defender V8 90.
Should be concerned at all about letting the car download the JLR update, given that I now have several things reprogrammed to my liking with my GAP tool?
Would I be at risk of losing any of my settings if I let the car go ahead download its update.
Still new to the whole JLR product and the GAP tool thing programming.
I keep cancelling out of the JLR update prompts for fear of losing any of my GAP tool programing.
Old Sep 17, 2024 | 01:11 PM
  #346
GavinC's Avatar
No. No concerns with OTA updates. Your changes will remain unaffected.
I have had lots of OTA updates and there is no impact on the ECU file changes made.
Old Sep 23, 2024 | 09:46 AM
  #347
yju's Avatar
yju
Default Hvac
Hi!
I'd like to deactivate automated air circulation. It activates in very cold temperatures (like -25 C) and windshield gets fogged. Otherwise HAVAC-system functions perfectly.
Old Sep 25, 2024 | 07:27 AM
  #348
starbai's Avatar
Originally Posted by hguiang08
Hi guys, I just found a cool new shortcut which may be on the 2025 update. I tried a bunch of combinations but I think it's 882 to enable the side bars on the ends of the screen. This way you can quickly adjust the AC temp, fan, drive mode, seat temps, volume. You also need to enable a few setting that if I recall were grouped in the 895 and you can choose what short cuts you want displayed such as window defrost etc. Those are called soft buttons.
any details? or luck yet?
Old Sep 25, 2024 | 07:51 AM
  #349
Kaylorsan's Avatar
I’ve got the shortcut window to appear as well as the ‘custom’ sidebars, however I can’t figure out how to add options in the sidebar.
From memory, the new button on my left sidebar contains TR Mode and the right side has a volume slider (see my earlier post for details)
I do not get any of the climate control options. While I was doing the setup, Pivi served up a ‘demo’ screen that included climate control icons, however my actual screen does not include them.
I was hoping that the 4.2 update would change things, however it has not.
Old Sep 26, 2024 | 08:42 AM
  #350
CincyRovers's Avatar
Originally Posted by jrjunior41
Question about Dynamic Mode as well:
I've read the thread and am aware of noticeable changes in Dynamic Mode with regards to manual shift performance. My question is how Dynamic affects the shifting/throttle if you leave the gear selector on Automatic. Like is the throttle more agressive in Dynamic/Auto versus Comfort/Auto or is it exactly the same?
With Dynamic Mode on and the transmission in D, the throttle response is a bit sharper, gears are held a bit longer and the transmission will sometimes rev match downshifts. With the transmission in S, the throttle response is the same, but gear changes are quicker, crisper and the transmission will rev match downshifts all the time. When the transmission is being shifted manually, the car will not auto upshift, like it will do in Comfort mode, instead, it will bounce off the rev limiter until you shift up.
