GAP IID Tool Summary
Old Mar 10, 2025 | 10:54 AM
  #441
isugoo's Avatar
Originally Posted by capjuancode
I created a gpt bot to search in this blog to avoid redounded question hope it works for you but always double check the system to see if it correct but I have tested it a couple of time it seems its working as expected. it also fallows the the gap tool manual if questions are needed.
https://chatgpt.com/g/g-U7gyA4J3E-ga...tics-assistant
Wow. Thanks for your support for our forums. This should be in the first post. I do not want this to be stuck in the middle and getting lost. Admin, can we do that??
Old Mar 10, 2025 | 12:12 PM
  #442
PNW Rover's Avatar
Amazing. Thank you!
Old Mar 11, 2025 | 03:55 PM
  #443
emariu's Avatar
Originally Posted by GavinC
This link should help you.
Get level with GAP.
Stevemfr said " you have to put the vehicle into 'Build Mode' first to keep the EAS from trying to level out when you leave 'Test Valves' if you want to sleep level in your RTT or platform in the vehicle" How to put vehicle in Build Mode??
Old Mar 11, 2025 | 05:12 PM
  #444
GavinC's Avatar
Just follow the outlined instructions in the linked thread. It's all there.
No "build mode" is present in the menu.
Old Mar 11, 2025 | 05:30 PM
  #445
emariu's Avatar
Thanks.. I did that
And next morning,when I pack and drive away, should I do the same procedure on a flat level or is the car doing that automatically on start and drive?
Old Mar 11, 2025 | 07:20 PM
  #446
GavinC's Avatar
Thanks.. I did that
If I remember correctly once you exit the mode it's all back to normal. Drive away. Nothing else needed. Might even revert to normal as soon as you hit one of the air suspension buttons. I can't remember. It's very quick and simple one way or another.
Old Mar 15, 2025 | 02:22 PM
  #447
MudDisco's Avatar
Default Turn off open door chime with GAP iid
Has anyone figured out how to turn off the open door chime? I don’t see anything in the settings and have yet to find a solution using GAP.
I can be in and out of the defender a lot when off-roading or trailer hook up. The chime drives me nuts.
Old Mar 15, 2025 | 11:03 PM
  #448
easyski's Avatar
Originally Posted by loudog3114
Anyone find anything on making the lane-keep system a full lane centering? I'm pretty confident this is the same system the jag i-pace has with full lane centering.
This would be amazing, have you tried any searches for potential settings?
Old Apr 10, 2025 | 08:15 PM
  #449
jrgdiscovery's Avatar
5th Gear
Originally Posted by Lantisbred
Just got my GAP tool and was looking to progam a new key. But despite updating the software and putting my rig into service mode via the LR app... I don't see any of the standard options under the main menu Service / Test.
Does anyone have experience with this issue and a solution? Here a screen shot of what I'm seeing.
Go to powerfuluk.com search program key or activity key , you don't do it through the service test I believe. I have programed two key by following their video
Old Apr 15, 2025 | 04:12 AM
  #450
honolulugator's Avatar
Default Turn off walkway horn honk?
Saw this asked earlier in the thread, but don’t recall seeing an answer.
With a door open and walking away from car with key in pocket you get the double horn honk… very annoying when packing for a trip or unloading groceries. Any way to turn this off?
