I replaced all the rubber and plastic coolant hoses. I also descaled the heater core, but discovered that somewhere along the line someone had crossed the heater hoses. I now have heat, and rock solid temps according to Torque Pro and the OBDII port. This weekend will see a complete brake overhaul (rotors, calipers, pads) as well as rear bearings and speed sensors. Last weekend I installed the terafirma rear shocks (TF119), and I've been amazed at the difference. The old shocks weren't that old, just not up to the task.
D*mn it, Joe. You're going to make me paint my wheels black again. That is sexy. Your two discos are the same colors as mine two, except the grey one is in pieces.
This disco 2 is bone stock and has 150k I think its time.
New parts are now on their way!!!!!
New suspension TF heavy Duty
New u joints Precision
New ball joints Precision
New brake lines Extended Stainless
New head gasket kit w/ bolts Proper Spec
New ABS sensors Wabsco
New ABS modulator valve Wabsco
New Tires 285/65/18 trail grapplers
New steering damper TF
Now to find the time to put everything on!!
Give me your opinion??? Is this a good start?
What else should I have done??
This is my first Discovery. Experienced knowledge is appreciated.
