Old May 19, 2016 | 08:32 AM
  #3271
TelecomRover's Avatar
Looking for options to upgrade my front tie rod. Any suggestions? Its next on m D2 to-do list.
Old May 19, 2016 | 08:29 PM
  #3272
Joemamma1954's Avatar
Got my transmission mounts in today, took me all of 30 minutes to replace both of them. Right side was in 3 pieces, left one was cracking. No more rattling of drivers side cat against the frame and put tranny and TC back its correct position.
Old May 21, 2016 | 10:28 PM
  #3273
BS50MGSXR's Avatar
got pads and rotors installed all around, 2 quarts of valvoline dot3/4 synth that will go in soon as i figure out the Nanocom's brake bleeding. but did successfully program one key fob to the truck so far of the 2 i have .
Old May 22, 2016 | 07:44 AM
  #3274
CollieRover's Avatar
Originally Posted by galchutt81
I'm about to rebuild the motor. Has anyone heard of putting a 4.6 cam into the 4.0? Never done a disco before I've always done Chevys and Fords. Any tips would be appreciative.
Turner Engineering sells a H180 cam that is a huge upgrade over stock for the 4.6 engine. I mean, really big difference. Also, Crowler makes one as well.
If you called or emailed Turner they would probably tell you all you need to know, they are great to deal with. It comes from England, but I got my short block from them and it did not take long, and was not inordinately expensive either, I am in Chicago so it may have helped being close to O'Hare.
Old May 24, 2016 | 07:08 AM
  #3275
dgi 07's Avatar
After dragging my feet and sitting on these for 6 months, new fog lights.
Cut the connector for the old fogs lights, Soldered in some 2 pin trailer connectors. on the harness and the fog lamp and boom, easily replaceable, cheap to replace for lamps.
Bolted to the front bumper support bar for rigidity.
Old May 24, 2016 | 05:46 PM
  #3276
dr. mordo's Avatar
Originally Posted by BS50MGSXR
Daedrix, Notice you don't have the under the hood padding or what ever that stuff does for the car? i was debating removing mine. is it really important at all to keep on?
I suspect it also helps protect the hood paint from engine temps.
Old May 25, 2016 | 07:35 PM
  #3277
BS50MGSXR's Avatar
i was thinking of getting a white hood (if i find one) from the junk yard and just cut the hood vents into it. those hood vents are expensive. Draw it out and cut away, and then i guess just paint the vented area with white or black rhino liner or something.
Old May 27, 2016 | 07:12 AM
  #3278
dgi 07's Avatar
Did spark plugs this morning. Had a "misfire" at idle but wouldn't trip the CEL. These plugs only have 25k on them, Bosch platinum. Oil is changed every 3500, engine air filter is changed every 10k and only premium gas is used
Went with NGK iridium this time around.
Attached Thumbnails What did you do with your DII today?-20160527_070101.jpg   What did you do with your DII today?-20160527_070117.jpg
Old May 27, 2016 | 08:15 AM
  #3279
wjsj69's Avatar
Default home-made rear bumper
Finished my rear bumper. I finally have real steel on all 4 sides now; I feel bad for the guy with a plastic car that is unlucky enough to run into me!
I trimmed some of the aluminum (or aluminEum, so all you Brits know what I'm talking about! ) from the rear quarters so there's less chance of getting hung up..
Attached Thumbnails What did you do with your DII today?-img_20160526_183729965_hdr.jpg   What did you do with your DII today?-img_20160526_183745582_hdr.jpg   What did you do with your DII today?-img_20160526_183717480_hdr.jpg
Old May 27, 2016 | 05:08 PM
  #3280
jbarr89's Avatar
Do you happen to have build pics? that thing looks nice and beefy!
