Old Dec 28, 2020 | 11:33 AM
  #7981
baileyrockhound's Avatar
i installed a new block heater for those days she is under the carport rather than in the warm garage.
it is an inline heater that slips into the lower radiator hose warms the coolant and thus the block for cold starts
Old Dec 31, 2020 | 08:13 PM
  #7982
Richard Gallant's Avatar
Pulled the valve covers on my "spare engine" and did an happy dance, will be doing small maintenance this spring. Push rods may also be new.
They look brand new
As well I found significant fouling of the lower manifold heater pipe and front water block water entrances with RTV. The shop suspected a failed block bit it may be simpler just restricted water passages (that would be nice bonus). Unfortunately the shop is very familiar with these engines so my be is they are right.
Old Jan 1, 2021 | 05:49 AM
  #7983
JUKE179r's Avatar
I haven’t driven Myrtle much of anywhere since changing the oil during the Tier 3 lockdown in December. This morning I started to recondition and trickle charge the battery with the CTEK XS 7000 charger since it will be sitting again even more during our Tier 4 UK lockdown.
Old Jan 1, 2021 | 10:39 AM
  #7984
Alex_M's Avatar
They look brand new
That looks incredible!
Old Jan 2, 2021 | 07:31 AM
  #7985
The_OGCJR's Avatar
Originally Posted by Docgrievous
can I get some info on your tablet install? Thinking of doing similar
Old Jan 2, 2021 | 07:35 AM
  #7986
The_OGCJR's Avatar
Started my ICE upgrade.
Made some mounting rings from Walmart cutting board
Old Jan 2, 2021 | 08:31 PM
  #7987
SeanBaker's Avatar
Removed, cleaned and greased my noisy in-car temperature sensor, as described here:
https://www.aulro.com/afvb/discovery...ng-column.html
Was super easy, except getting those two screws out can be tough. This little gem made all the difference (for $3!):
https://www.harborfreight.com/8-piec...ver-92630.html
Now it's silent! It's been on my list for a while, so it was nice to check it off in the new year.
Old Jan 2, 2021 | 09:58 PM
  #7988
RoverN8's Avatar
Default Oil, oil and more oil
Changed the gear oil in both diffs and the transfer case. At 160K I'm not sure if the rear was ever done by the looks of the gunk that came out and was attached to the drain plug. Probably about half an inch or more sludge attached to the plug...not sure what that is going to lead to later. Front diff was pretty clean but the truck had its front diff replaced by the dealer during its lifetime. The transfer case seemed clean but a little low. Messy but I'm glad it's done!
Old Jan 3, 2021 | 01:10 AM
  #7989
The Deputy's Avatar
A fine crown of material on the plug is normal. The ring and pinion are probably the two largest gears in the entire drivetrain...and handle a great deal of stress and pressure...so, wear is inevitable. A fine or somewhat spiky crown of material will appear on plug during change, especially the first. Unless you are seeing chunks or strips of material...nothing to be alarmed about.
Nice looking 04.
Old Jan 3, 2021 | 09:53 AM
  #7990
merebel's Avatar
Finally got the sliders/steps done and installed.
overall very happy with them. Not the best time of year doing this in Maine. Will have some adjusting to do in spring when it’s warmer out.
