Old May 21, 2023 | 11:13 AM
  #9271
mln01's Avatar
Originally Posted by Xanthro
Changed all the Turn Signal bulbs to LED, this meant putting in a Load Equalizer for each bulb.
I used the ones from Sylvania.
I'm genuinely curious; why do people do this?
I understand LEDs have a longer service life, but I have had my truck 21 years this month and have had only one, maybe two turn signal or other exterior lamps fail. Not exactly onerous.
Old May 21, 2023 | 12:22 PM
  #9272
Xanthro's Avatar
Because when one bulb goes, the others will likely fail soon, and a bulb failed on the vehicle. While, other bulbs may also last another 20 years, LED bulbs will last essentially forever.
Plus, if you replace one bulb with an LED bulb, the color value of the other bulbs looks odd, as they are a different color and different lumen value. Regular bulb can actually get washed out by other lights when the others are LED.
Having to put on a load equalizer is annoying and expensive, but it's pretty much a one time thing ever. Total cost of each LED Bulb including the load equalizer was about $25, compared to $3 for a bulb replacement, but the higher visibility is worth it to me.
Old May 25, 2023 | 05:34 PM
  #9273
Richard Gallant's Avatar
Shock towers the old ones were done - about an hour to get both done and a few other little things cleaned up.
Old May 25, 2023 | 06:46 PM
  #9274
Disco Rocks's Avatar
4th Gear
What is the brand of these shock towers? Thanks!
Old May 25, 2023 | 07:32 PM
  #9275
@Disco Rocks Ordered from Land Rover Direct in England the brand is Britpart
https://www.lrparts.net/da3296-xs-fr...rd-height.html
250 cdn tax and shipping in to my door in 3 days
Old May 25, 2023 | 09:55 PM
  #9276
hasullivan's Avatar
It what seems to be a typical thing for me I have not images but...
Instead of the cross country trip we spent that time in Big Bear and Idlyllwild (CA). Got a chance to hit about 6 trails in Big Bear and 2 in Idyllwild.
Cracked up the bottom (in front of support) bumper yoloing my way out of an poor choice (Idyllwild trail was in bad shape). Truck did great.
Today I installed sway bar disconnects and heading back to Big Bear this weekend. It will be nice to get feedback on any improvment it makes.
As I am nearing a year of ownership I am beginning to plan out what mods I want to perform over the year.
Old May 26, 2023 | 09:11 AM
  #9277
YETIX's Avatar
I'll be curious to hear how the trail are in Big Bear, I'm heading up next weekend. With all the rain and snow we had, I'm worried the trails will be trashed.
Old May 26, 2023 | 10:27 AM
  #9278
hasullivan's Avatar
Ill shoot you a message.
Old May 26, 2023 | 02:01 PM
  #9279
Trailmix's Avatar
@Richard Gallant how did you know the old towers were bad? What symptoms?
I have a loud metallic single clunk when i turn in either direction over a small bump like the curb at my driveway. It only happens on the first turn of that direction and then reoccurs the first time i go the other direction over a small bump. I also have a vibration in my steering wheel only when I turn right at idle or under 5mph.
After some research, I suspect a bad/loose shock tower, but not sure... your symptoms would help me diagnose my problem.
Old May 26, 2023 | 02:48 PM
  #9280
@Trailmix The old ones were delaminating, you can see it in the image. Both were starting to split so it was time.
I have a slight vibration at 50 mph in mine but the tie rod ends are gone, so that gets looked at shortly.
