My D5 build 2017 TD6 HSE Lux
Old Apr 23, 2024 | 07:29 AM
  #241
gmfain's Avatar
Here is my recall doc.
Old Apr 23, 2024 | 09:17 AM
  #242
gmfain's Avatar
In Preparation for tranny service.
File from ZF
File Type: pdf
Old May 1, 2024 | 02:24 AM
  #243
adam5's Avatar
Since this is a rich thread on general D5 maintenance, I thought I'd ask here;
would it be worthwhile cleaning/de-greasing the throttle body [LR078546], as part of maintenance?
removal & install seems easy enough. thoughts??
Old May 1, 2024 | 05:00 AM
  #244
gmfain's Avatar
This is a job I am planning on doing. I think it will be beneficial.
Of course, if you tackle it first, take pics and give us your feedback.
I'm at least three weeks out to do it.
This weekend Evoque tranny and diffs..... My VW is at my gurus for clutch kit.... Next weekend is Spring Safari Uwharrie NC.......9-12th
Old May 2, 2024 | 04:31 PM
  #245
adam5's Avatar
Any chance you'd have torque specs on the throttle body bolts? I can give it a shot but I don't want to over-tighten things on re-assembly.
I'm still debating if I should remove the butterfly valve motor and submerge the remaining composite part in a detergent/oven cleaner mix of some kind vs. clean the whole assembly with a toothbrush + brake cleaner (avoiding motor disassembly + re-adaptation).
Old May 2, 2024 | 05:33 PM
  #246
gmfain's Avatar
Toothbrush and carb cleaner is what I use on my LR3 and my friends Roo.
I'll have to try and find torque spec.... In the meantime my guess is 6 to 8 Nm
Old May 6, 2024 | 12:29 PM
  #247
gmfain's Avatar
Bad news for my oil level sensor. She gone. I won't be fixing that anytime soon. Got to pull motor, Its in the oil pan.
Oh well, on to Uwharrie Safari this weekend in NC!
don't look at the P2002, LOL
Old May 6, 2024 | 12:54 PM
  #248
ar077's Avatar
Oil level indication failure was the first (and only) chronic problem in my new D5 after I took delivery in 2017. Took it in for service several times (all under warranty) but whatever they did to restore it didn't last until they ordered a new sensor and, after installing it, made sure all connections were secure. Haven't had any problems with it since then. I've now owned the D5 long enough to know that it doesn't use any oil so if the oil level sensor fails again, I'm going to ignore it. I find it incomprehensible that the engine does not have an engine oil dipstick and I'm wondering if the identical engine used in Ford vehicles here has a dipstick.
Old May 6, 2024 | 01:34 PM
  #249
gmfain's Avatar
I agree, let it ride.... I am going to throw a hail Mary at it for the last extended warranty claim. I can take it in on 5-17-24, and see what they say.
Old May 14, 2024 | 08:49 PM
  #250
adam5's Avatar
Default Throttle body inspection
I tried opening the throttle body but couldn't get the locking clip off. Removed the air intake hose instead and used a borescope to check the carb build up.
Interestingly, to the naked eye it doesn't seem so bad @35k miles. Borescope camera makes it look a lot worse (I'll post pictures shortly).
I hope to take another swing at it over the weekend.
