My D5 build 2017 TD6 HSE Lux
Old May 23, 2024 | 10:52 AM
  #261
gmfain's Avatar
Update on oil level sensor diagnosis. Plus oil leak.
My continental warranty will cover it. But I would have to pay the difference in parts and labor rate. Which is $1500. I said no thank you, let it ride.
So when I changed my tranny fluid, I noticed I had a small oil leak.
continental warranty will not cover the oil leak.
I will post details on oil leak later. But I gave the dealer a bone and let them fix the oil leak. $540 approx.
Note: continental warranty labor rate in$135 per hour. JLR labor rate is $250 per hour.
Old May 28, 2024 | 02:42 PM
  #262
gmfain's Avatar
My D5 is ready to pick up. My leak was coming from the Oil separator. (LR054999)
here is invoice.
File Type: pdf
Old May 28, 2024 | 02:48 PM
  #263
1979rover's Avatar
Good to know and glad it's solved.
I just wish LR would state that the Oil separator is designed to separate oil from the vehicle to the outside world.
Old Jun 3, 2024 | 09:09 AM
  #264
gmfain's Avatar
Exclamation
So I pick up my D5 Saturday, I got almost home BAM:
DPF full warning.
P2463-00
P2080-64
P0234-77
P049B-00
Dealer/service advisor hasn't returned my call. Maybe they left something unplugged???
My Indy mechanic said this morning to, 1st thing is to check all vacuum lines in the area of the oil separator .
I will when I get off work today.
Saga continues.
Old Jun 5, 2024 | 04:13 PM
  #265
adam5's Avatar
Originally Posted by gmfain
I'll be honest, my mechanic told me too every other oil change. I trust him fully. Try it, hopefully it will solve the problem. It's a pretty easy procedure. Just have the extra clamp, as a stand by.
Bosch part # 0-44-021-007 Injector Clamp, pretty universal for DEF https://www.carparts.com/intake-clam...h/bs0444021007
@gmfain is there another place to purchase this part? The carparts link seems to be broken.
Old Jun 5, 2024 | 04:34 PM
  #266
1979rover's Avatar
I bought a few spares just in case. They're cheap.
Old Jun 5, 2024 | 07:01 PM
  #267
gmfain's Avatar
https://thmotorsports.com/12619299-bosch-0-444-021-007
Old Jun 6, 2024 | 11:10 AM
  #268
adam5's Avatar
thank you both. the part search led me down a rabbit hole. it appears the OE part (0009951133) is on FCP as well. posting for other folks
https://www.fcpeuro.com/products/mer...sch-0009951133
Old Jun 7, 2024 | 03:16 PM
  #269
1979rover's Avatar
Awesome, that's where I got mine.
Old Jun 10, 2024 | 02:30 PM
  #270
gmfain's Avatar
Back to my saga/adventure.....
I took it out on the highway Saturday. It did a Regen cycle. Cel came back on before I got home.
P2080-64
P2002-00
P049B-00
It seems like the bank 1, Sensor 1 is failing? B1S1
cel is on.
Here is a image of recorded temps.
The 914 temp should be near the 683 range.......... based on past times checking these temps.
When in regen B1S3 and B1S4 will be around 1200 degrees.
(The App is Torque)
Any thoughts?
