Small Modification Write Ups + Index of Mods (Alex_M)
Old Sep 6, 2015 | 09:09 PM
Alex_M's Avatar
Default Small Modification Write Ups + Index of Mods (Alex_M)
Ok guys, I'm going to compile a list of smaller mods I do here. These are just mods that aren't big enough for their own posts but I think are worth sharing anyway. And of course, I'll do an index right here on the first post with links to each mod's respective page. Keep an eye out on here because I will keep it updated semi-regularly.
Some prices will change over time. The posts reflect the price of parts at the time of my writing the write up and will not likely be updated later.
Some of these write ups are pretty old at this point. Feel free to as clarifying questions. Some products may no longer be available, but most should be and hopefully alternatives are available for those that are not.
Commonly searched information:
Tire size fitment at various heights - pg. 15
Major 60k Mile Service - Revised
Index of my small mods:
Keep your Disco cooler in the sun ($55) - Pg. 1
Reverse lights that will blind you ($22) - Pg. 1
DIY Hi-Lift Jack Mounts ($10) - Pg. 3
DIY Schrader Valve Tool (Free) - Pg. 3
Valve Cover Bolts with Allen Head ($10) - Pg. 3
In line fuel filter addition ($6) - Pg. 6 - only recommended with change to modification listed at the beginning of post.
Oil breather filter modification ($20) - Pg. 6
Aftermarket Temp Gauge ($35) - Pg. 7
Optimal In-Line Thermostat Temp - $12 - Pg. 14
Standard Wiper Blades on D2 Arms ($15) - Pg. 14
How to remove chrome lug nut caps (Free) - Pg. 14
Links to my larger mods and write ups:
DIY $120 Lift
How to make a cold air intake, by request ($65 + optional filter)
Homemade Sway Bar Quick Disconnects ($10)
Another electric fan conversion, for $70
Hood prop no more! How to get your hood prop out of the way forever. ($22)
A/C Delete Mod ($23)
DIY Injector Cleaners and Alternative O-Ring Part Number ($15)
Fuel Pump Removal and Disassembly
Oil Pump and Timing Chain Replacement Write Up
Hedman Header/Full Exhaust System Install Not a great write up, but plenty of info to get someone started. I lost a lot of pictures I meant to include in this one which would have made it a lot better.
DIY Lowered Shock Towers (Free, welder required)
Differential Replacement Write Up (Front or Rear)
Secondary Transmission Cooler Mod (~$85)
Rear bench to shop bench conversion. (Shop upgrades, welder required)
Pontiac Blower Motor Swap ($20-35)
Rear Rotoflex Delete / U-joint Conversion ($125)
Panhard Conversion w/ All Factory Parts ($50, welder required)
The Ultimate Cooling System; Complete System Upgrade - (~$220) - Unfortunately this is not an entire write up, but there's lots of info here; plenty to get the job done.
Tools and Equipment I Carry Full Time
How to Rebuild Brake Calipers
My Incomplete Mods:
Powertrain Swap! Another route to LS power. (Currently making slow progress.)
Turbocharging a 4.6 V8 (Probably $2500 before the turbos) (Cancelled. Lots of info here though)
24 lb Injector Upgrade ($75) (Cancelled, but good info)
Looking to the future... Bobbed, chopped, and trimmed. (Plans have changed, lots of ideas)
Help me butcher a D2 - LS Swapped RWD IFS Conversion (on hold?)
Mods and write ups by others that seem handy:
(PM me recommendations!)
Dr. Mondo - Thread of DIY Mods, Repairs, and Useful Info - Lots of mods here.
RoverMasterTech - Main/Crank Bearing replacement write up
Shade Tree - Here We Go Again, My LSX Swap Thread
Land Rover Club V.I. - Inline Thermostat Mod
Charlie_V - Redneck AC vacuum for charging
R0VERGUY - My 03-04 Headlight conversion with pics
Charlie_V - Pickup tube o ring SOLVED
Greisinb - 3D Printable Parts Collection
Useful Factory Manuals:
Electrical Circuits Diagrams
Workshop Manual
V8 Overhaul Manual
Other Support Docs & Original Source
Old Sep 6, 2015 | 09:15 PM
Alex_M's Avatar
This one is most recommended to do while you have your headliner out. Go on amazon and buy a roll of Reflectix. Take that and cut it to fit in the roof of your disco. Tape it up there and then re-install your headliner. I noticed a difference in temperature as soon as I finished the first row across and I've noticed a difference every morning and day since. This is a big one, especially if you don't like to use your A/C. It should also keep it warmer in the winter. Also, you can see I got the 24"x50' roll of Reflectix. Don't get one that big unless you're also planning to make window covers (I am) because you'll have a ton left over.
I'll do one for those two fans once I get the chance.
Old Sep 6, 2015 | 09:18 PM
Alex_M's Avatar
Very simple. These are two LED light bars, $11 each shipped, and they will splice right into the factory wiring. There are no relays needed because the wiring is the same gauge as the factory wiring. They are not getting warm at all and they work 10x better than the factory reverse lights with LED bulbs.
Link to lights
Old Sep 8, 2015 | 09:30 PM
Joemamma1954's Avatar
[QUOTE=Alex_M;534771]Ok guys, I'm going to compile a list of smaller mods I do here. These are just mods that aren't big enough for their own posts but I think are worth sharing anyway. And of course, I'll do an index right here on the first post with links to each mod's respective page.
Alex,
I am definitely going to do the insulation mod, when the headliner job comes up. I am also contemplating getting all the windows tinted as dark as allowed by law, including the moonroofs.
I also came across an old thread, relating to under the hood light. I have had Chevy trucks since God knows when, and they use to put in a retractible light that extends 18' and has its own switch. I found a seller on eBay that sells them for 29.95 which includes the wire connector(gm sells light and connector separately for around 80.00). The light itself has a magnetic base and can be stuck wherever you need it. GM mounted it on the fender well, but I saw where a guy mounted it on his hood, in the center, where it would light up the hole engine and could easily be pulled out to either side as needed.
Joe
Old Sep 9, 2015 | 07:49 AM
Dan7's Avatar
Replace t-case and e-brake boots with leather one's from redline:
Shift boot store - RedlineGoods leather shift boots
Stitching to match my tundra interior and never flake again!
Old Sep 9, 2015 | 08:01 AM
Charlie_V's Avatar
Joe, what are the fans for? I can't see that picture well on my phone but are those on the sun roof?!
Old Sep 9, 2015 | 11:19 AM
I am assuming for ventilation. It is Alex's picture. I am going to install the insulation, shown, but not the fans.
Old Sep 9, 2015 | 12:12 PM
cappedup's Avatar
Creates extra downforce at the back. More tyre grip. Extra acceleration getting away from stop lights.
Old Sep 9, 2015 | 02:25 PM
Now why didn't I think of that.
Old Sep 9, 2015 | 02:48 PM
Default Another cheap mod
My E-brake boots were shot and clips broken on moonroof sunshades. Got the fix here:
https://landroverforums.com/forum/pr...05/#post221668
