"Write ups" , "How To's" , and "MUST Reads"
Old 11-05-2009, 10:19 AM
jycsalas's Avatar
Exclamation "Write ups" , "How To's" , and "MUST Reads"
This section is for "Write-ups" and "How to's". The threads are divided by sections and we will continue to add more as they are made by our members.... so next time you do a job on your rover, document it and take pictures! Also please contribute relevant responses to them, don't ask about getting tires or a lift in the "how to flush brakes" thread. Irrelevant comments will be deleted. READ THE ENTIRE THREAD BEFORE ATTEMPTING THE REPAIR/FIX SO AS TO FIND OUT THE RESULTS OF THOSE WHO HAVE DONE IT.
******** Proceed with any of these instructions at your own risk! *********
NEW MEMBERS PLEASE READ!!!
New Members - - -
Locked out? Read this first
https://landroverforums.com/forum/di...d-works-45005/
Alternator
Alternator Dis-assembly DII
Transmission
- Change the trans fluid on a DII
Transfer Case
- Change Transfer case oil/ Re-seal cover plate - DI/DII
- Reseal transfer case
Ignition
- Replace wires without removing IM DII
- Replace coils and/or wires (remove upper intake)
- LR03NJ Coil Pack Relocation Project
- Crankshaft position sensor DII
- Key Fob Repair DII
- Starter Replacement DI/D2
- Ignition Lock Repair/fix DII
Fuel
- Remove Discovery I Fuel Pump / Fix
Interior
- Paint D2 headliner board
- Door Lock Actuator Replacement D2
- D2 Blower Motor Overhaul
- PNP BOSS Audio 616UAB Headunit
-D2 Fire Extinguisher Mount
Exterior
- Painting Faded Fender Flares D2
- D2 Windshield Cowl Filter
- D2 Hood Prop Mod
Cooling
- Fix Throttle Body Heater Gasket D2
- DI Aux Electric Fan Part #
- Water Temp Gauge
Engine
- **MUST READ for anyone doing HEAD GASKETS or VALVE REPAIR**
- Seafoam Induction Cleaning DII
- Throttle body cleaning
- Replace SAI Pump Filter
-Oil Pressure Gauge DII
-Main/Crank Bearing Replacement DII, by RoverMasterTech
Adding a DI Transfer case CDL to a DII Transfer case
https://landroverforums.com/forum/di...non-cdl-52590/
Maintenance Information
60K Service and more for used vehicles see also Major Service for 60k plus
Brakes
- Flush brake fluid
- Fix ABS Modulator Shuttle Valve Switch error code
- Stainless Steel Braided Brake Lines DII
- Replace ABS Shuttle Valve Seals
Suspension
- SLS to Coil Conversion
CDL - Center Diff Lock
Cdl kit install instructions
04 CDL Shifter Installation Video
Drivetrain
- Differential Removal DII
- Rebuild Prop Shaft double cardon u-joint (antichrist)
- Driveshaft Rebuild (Antman)
**DII Front driveshaft rebuild Part #'s U-joints are Precision 344 (3 required) and Centering ball is Precision 617 (1 required)**
(Off-road France) driveshaft rebuild http://http://www.discovery2.co.uk/propshafts.html
Documents or Articles
DII: What is a Land Rover Discovery and Where did they come from
DII: Recalls, Service Bulletins, Technical Alerts, Technical Bulletins
23 Upgrades For '94-'04 Land Rover Discovery
Buying a Rover
DI & DII Side by Side Comparison
What to look for when buying a Land Rover Discovery
Buying a 2003 DII
Helpful member sites 7 links
https://landroverclubvi.weebly.com/
www.discovery2.co.uk (Urban Panzer)
Dr. Mordo Misc Mod Links
The following 10 users liked this post by jycsalas:
Disco Eagle (02-10-2018), eseattleseattle (05-26-2016), galchutt81 (01-11-2016), GunnerandDeena (05-24-2016), JUKE179r (11-26-2016), OkraKing (01-23-2021), Quest4ADV (11-29-2018), shadycake (10-05-2021), Tennessee Disco (01-21-2016), Toran (09-05-2015) and 5 others liked this post. (Show less...)
Old 05-23-2019, 03:02 PM
Best4x4's Avatar
Received 2,244 Likes on 1,664 Posts
Checked for dead links, and while some pictures are gone the info is still valuable. Added new links
The following 2 users liked this post by Best4x4:
jastutte (05-23-2019), Richard Gallant (05-23-2019)
Disco101
11-16-2017 11:40 AM
Spike555
ROAMING WITH FRIENDS
09-07-2010 01:17 PM
Disco Den
02-25-2010 12:53 AM
elboy0712
02-07-2010 07:45 AM
ljdiscovery
07-18-2008 08:51 PM
Quick Reply: "Write ups" , "How To's" , and "MUST Reads"
