Discovery Series I Tech Section
Old Jul 9, 2010 | 08:46 PM
Default Discovery Series I Tech Section
Land Rover Maintenance Schedule
http://www.landroverresource.com/docs/D2_03-04.pdf
Rave Manual
https://landroverforums.com/forum/ge...-images-42972/
Engine Oil and Filter
https://landroverforums.com/forum/di...estions-46975/
VSS Rebfurb
https://landroverforums.com/forum/di...ing-vss-56298/
Disco Mike's List
https://landroverforums.com/forum/di...h-miler-42471/
Locked out? Read this first
https://landroverforums.com/forum/di...d-works-45005/
How to rekey your ignition tumbler
https://landroverforums.com/forum/di...ock-fix-35422/
Alarm By Pass
https://landroverforums.com/forum/di...-bypass-46728/
https://landroverforums.com/forum/di...-detail-53613/
https://landroverforums.com/forum/di...sco-tip-55071/
Alarm bypass for Lucas FI (RRC and 1994 and 1995 Disco)
How to install the RAVE manual to your iPhone
https://landroverforums.com/forum/di...-iphone-42491/
How To Use The Transfer Case Shifter
https://landroverforums.com/forum/di...er-case-40801/
How a Differential Works
https://landroverforums.com/forum/di...l-works-40804/
What to look for when considering a Discovery
https://landroverforums.com/forum/sh...ad.php?t=21328
Series I and II side by side comparison
https://landroverforums.com/forum/sh...ad.php?t=28599
New to You Recommended Parts and Service
https://landroverforums.com/forum/sh...ad.php?t=36324
Loose Steering
https://landroverforums.com/forum/di...se-read-45139/
Death Wobble Check List
https://landroverforums.com/forum/di...86/#post367502
Oil Drain Plug Size
1 1/8" -A combination wrench works best.
Oil Change Tip
If using automotive ramps run both passenger (right side) wheels up onto the ramps, this will place the oil drain plug down and make it easier to grease both prop shafts.
Fan clutch replacement
https://landroverforums.com/forum/sh...ad.php?t=32370
Correct belt routing
http://www.roverparts.com/TechTips/s...g_defender.cfm
Transfer Case
https://landroverforums.com/forum/sh...ad.php?t=27159
Transmission Filter Replacement
https://landroverforums.com/forum/sh...ad.php?t=34270
Thermostat Gasket Part Number per AntiChrist
Fel-Pro 12994
Fuel Pump
https://landroverforums.com/forum/sh...d.php?p=152377
ABS Trouble shooting
https://landroverforums.com/forum/sh...ad.php?t=34025
Aux cooling fan aftermarket part number
https://landroverforums.com/forum/sh...ad.php?t=31894
Condenser Fans Cheap Fix
https://landroverforums.com/forum/di...ser-fan-42888/
Throttle Body Cleaning
https://landroverforums.com/forum/sh...ad.php?t=19664
Flushing Brake Fluid
https://landroverforums.com/forum/sh...ad.php?t=23074
Stainless Steel Brake Lines Install
https://landroverforums.com/forum/sh...ad.php?t=33785
Pollen air filter replacement
https://landroverforums.com/forum/sh...ad.php?t=32561
How to make your own "Saudi Grill"
https://landroverforums.com/forum/sh...ad.php?t=33088
Chevy power steering pump modification
https://landroverforums.com/forum/sh...ad.php?t=35013
http://www.scribd.com/doc/53983445/D...ump-Conversion
Discovery Series I headliner replacement.
https://landroverforums.com/forum/sh...ad.php?t=33276
Dizzy vacuum advance replacement
https://landroverforums.com/forum/sh...ad.php?t=33384
Subwoofer repair
https://landroverforums.com/forum/sh...ad.php?t=35215
Propshaft rebuild
https://landroverforums.com/forum/sh...ad.php?t=29302
Starter Replacment
https://landroverforums.com/forum/sh...ad.php?t=33418
Ignition Lock Repair
https://landroverforums.com/forum/sh...ad.php?t=35422
Heavy Duty Spring Install
https://landroverforums.com/forum/sh...ad.php?t=35485
Swivel Ball Preload
https://landroverforums.com/forum/sh...ad.php?t=36607
Land Rover Discovery Series I wheel bearing part numbers per AntiChrist
Timken SET37, SKF BR37, *** KIT3 or National A-37
Hub seal part number- RTC3511 (double lip seal)
Windscreen wiper issues w/wiper motor replacement
https://landroverforums.com/forum/sh...ad.php?t=38067
jump seat instal
https://landroverforums.com/forum/ge...disco-i-57919/
Engine Information
https://landroverforums.com/forum/sh...ad.php?t=37551
Seat Repair
https://landroverforums.com/forum/sh...ad.php?t=38148
Speaker Options
https://landroverforums.com/forum/sh...ad.php?t=37318
Window Roller Repair
https://landroverforums.com/forum/di...-repair-39684/
Window Roller Repair part "B"
https://landroverforums.com/forum/di...-method-40257/
Steering Box Rebuild
https://landroverforums.com/forum/di...ear-box-40603/
Fuel Tank Filler/Vent Hose Replacement
https://landroverforums.com/forum/di...nt-hose-41987/
Radiator Plug
https://landroverforums.com/forum/di...or-plug-41294/
Rotor Replacement
https://landroverforums.com/forum/di...earings-44462/
Lug Nut Stainless Cover Removal
https://landroverforums.com/forum/di...removal-46843/
Wiper Switch Repair
https://landroverforums.com/forum/di...tch-fix-46886/
Correct JATE Ring Installation
http://defender110.nightmail.ru/Extr...TE%20Rings.jpg
Electric Oil Gauge Sandwich Adapter Thread Size
https://landroverforums.com/forum/di...emp-psi-48177/
Main Rod Bearing Replacement
https://landroverforums.com/forum/di...rite-up-48197/
A/C Delete-Serpentine Belt
https://landroverforums.com/forum/di...ne-belt-49753/
Parking Brake Gaiter Replacement
https://landroverforums.com/forum/di...ke-boot-49852/
7 Pin Travel Trailer Wiring
https://landroverforums.com/forum/di...-towing-51669/
Back Windows Not Working?
http://www.roverparts.com/Parts/AMR1282RK.cfm
http://www.lrrforums.com/showthread....ift-ECU-How-To
Helpful web sites
www.connectorsfast.com
http://www.landroverclubvi.com/rover-tech.html
http://www.discovery2.co.uk/
http://www.carbibles.com/engineoil_bible.html
http://minimopar.knizefamily.net/oilfilters/index.html
http://www.rangerovers.net/discoparts/index.html#air
http://www.britishstarters.com/Land_Rover.html
Please do not reply to this thread, if you have a question please start a new one, any reply will be deleted.
Old Jun 7, 2015 | 07:04 AM
TOM R's Avatar
adding mp3 to factory radio
https://landroverforums.com/forum/di...tion-d1-52617/
sea foam cleaning
https://landroverforums.com/forum/di...ies-1-a-62342/
https://landroverforums.com/forum/di...il-leak-75461/
Volvo injectors upgrade 1275194
Old Sep 24, 2015 | 07:34 AM
WaltNYC's Avatar
Default Easy RAVE downloads....
wmlj970e.pdf = workshop manual....aka: RAVE. The bible for these trucks
etlj970x.pdf - electrical troubleshooting manual.
hl01561n.pdf - owner's manual... highly optional
Click here for pdf versions ….
https://drive.google.com/drive/folde...fg&usp=sharing
Old Apr 6, 2016 | 12:55 PM
WaltNYC's Avatar
Vehicle Speed Sensor (VSS) rebuild....
VSS_rebulid_v1.pdf
Old Apr 7, 2016 | 02:22 PM
Roverfanatic's Avatar
This is an awesome thread Spike!
Thanks,
Tex
Old May 19, 2016 | 10:18 AM
WaltNYC's Avatar
Default Pre-AEL canister vs. AEL canister
Non-AEL canister....
AEL (late 1997) canister...
AEL square canister<br/>late 1997 and beyond
Old Jul 2, 2016 | 04:36 PM
Marty_deux's Avatar
Default tres amis plus
Finally got to a scanner that reads it all and puts results in words nearly Californio. AFR/M 02177 AFR/M 02188 pcm may be suspect or clean MAF. Ok, that can't hurt. Nailed it down to (mech and self amazed it runs) max fuel pressure at rail 20psi when running smooth, 10 when running ragged. There is too much gas going back to tank (check valve?) and/or all caused by not enough 'oomph' from pump or plugged filter. Buddy has pristine pumped (didn't know you could) 69 Shelby GT500, mmmm bebe. He also has made superb birch steering wheel for it and could be coerced into more.
Have read posts by Mike, SavannahBuzz and couple others but can't quite decipher any common point. Did have outside air showing at -21F when +/- 80F. Plan from this point is clean MAF, new filter and test. If NO then get decent pump for assy and dive into tank. Any thoughts or missed stuff greatly appreciated. Thanks, Peace and happy Independence w/e.
Old Jul 2, 2016 | 04:40 PM
Marty_deux's Avatar
Default Disco 1 or 2?
1998 4.0 (says so on top) with V8i emblem/decal in back. When searching with V8i as word results point to 3.9 engine. Some days it is better to stay in bed, some it is not. Jest a thought.
Old Jul 2, 2016 | 04:42 PM
Marty_deux's Avatar
sounds like a roll in the park ) or at my ranch. lostvalley.4t.com
Old Sep 28, 2016 | 06:59 AM
WaltNYC's Avatar
GEMS OBD manual
File Type: pdf
